Electrical problem
Old Feb 14, 2007 | 11:57 AM
bmorin@aviajets.com's Avatar
Default Electrical problem
Hi gents,
Need some help. I changed left turn signal bulb from the top with headlights open. After changing the bulbs I wanted to close the lights the headlights motor would not response, also lost the back running light and lost the dash lights!!!??? Any suggestions? Question #2 If the zener diode by the a/c compressor go bad will it prevent the compressor to turn on(changed the hole a/c system a year ago with a rebuit compressor)cause now it does not turn on and summer is on its way. Thanks in advance for the help.
Old Feb 15, 2007 | 05:31 PM
Dave01's Avatar
Default RE: Electrical problem
Did you check all fuses? This is what I would suspect.
Toothdr227
Jun 29, 2007 08:25 PM
daveboone
Apr 1, 2007 07:59 PM
jampa
Jan 14, 2006 09:17 PM
dag7330
Nov 5, 2005 08:58 PM
Tom
Sep 21, 2005 02:35 PM
