Reset Ride Control ?
Ok guy's here's one for you. My car is 99 coupe, it came with "RIDE CONTROL". For about 2 weeks the DIC has been reading RESET RIDE CONTROL.
the onel code I get is a steering one. If anyone has ever had this happen I would love to know what the couse was.
is this history or current? The code is set when a loss of steering wheel position signal from the EBCM to the ESC module. Either one or both of the modules can be bad, a bad wire, could be the steering wheel position sensor is at fault....but that may set codes as well. What module was the code in...the EBCM or ESC?
