suspension questions
Old Jul 18, 2009 | 10:16 PM
Architect's Avatar
Cool suspension questions
hey everybody. i think i finally got to the bottom of my random P0410 code. As you may know, that code relates to an air system failure. the pump is good, but the code kept coming up randomly every three or four times of driving the car. mostly it would cause the light to come on when i hit the brakes, as if a loose wire or something? anyhow, finally got up the nerve to dig into it more. ended up taking off most of the passengar headlight assembly, and the whole inner and outer passenger fender - which is a big feat for me.
come to find one of the air tubes was stretched as tight as it could be, and i found a cut in it. took it off to go find a replacement, and in the process found several large holes in the tube. since we live out in the country i have had problems with field mice when i leave any one of our cars sitting for too long. anyway, got that all replaced and put back together.
in the process of putting it all back together i noticed the rubber around the ball joint looked dry, and cracked. now i haven't had any unusual tire wear, but it still got me to thinking, probably should grease those up, or maybe even replace both and get an alignment before the next set of tires. i've swapped out balljoints before, but not on a corvette. is it going to be any different from changing one out on say, a camaro? didn't look much different. as long as i use the "official" ball joint pulls, should be easy right? (my very first vehicle was a 1969 chevrolet shortbed stepside, which my dad and i rebuilt from the ground up. i must say, changing the ball joints was the most tedious task on that whole truck - we finally had to get a blowtorch out, heat the dang things up and pound them out - the typical tool simply wouldn't knock them loose). anyway, have any of you ever replaced the ball joints on your c5?
Old Aug 15, 2009 | 05:51 AM
Bistinaws's Avatar
Default suspension questions
Sorry man, but this is just taking too long to come together. I ordered a new set of KYB GR-2s from rockautollc on ebay for 272 and free shipping and theyll be here Friday. good luck peddling the suspension stuff......and maybe re think the price.DM&FS
docmbnbkos
Jul 28, 2016 07:08 PM
bobbyj
Sep 25, 2006 11:07 PM
roflowj
Feb 8, 2006 12:49 PM
bobbyj
Sep 22, 2005 12:45 AM
korvette4u
Aug 6, 2005 01:18 PM
