Corvette C6 Forum 2005+
STALE ODOR OUT OF VENTS
Old Jul 4, 2008 | 06:25 PM
WHISTLER53's Avatar
Default STALE ODOR OUT OF VENTS
Hi, I own a 2006 Z51 & when the car is started after sitting a few hours or overnight in the garage a stale odor comes out of the air vents for approximately15 - 20 seconds. has anyone experience this issue if so do you know the cause & what can Ido to cure this minor issue ???? thanks in advance.
[IMG]local://upfiles/7658/A5181F14EA2E4A0CAD9117C09013C007.jpg[/IMG]
Old Jul 5, 2008 | 11:45 AM
tclhb's Avatar
Default RE: STALE ODOR OUT OF VENTS
Not sure if this is your problem, but if you are using the A/C it might be.
When you run the A/C, you can end up with moisture at the condensor. A few minutes before you get to your destination, use the A/C off button (snowflake with a line through it), run up the fan speed manaully to high. You will feel just as cool. There is enough left over cooling power to last for minutes. This will help to dry everything out before you shut it down.
This will help to avoid mold and mildew. I have always done this with all the cars I have had, and never had a problem with mold.
Old Jul 5, 2008 | 04:02 PM
WHISTLER53's Avatar
Thank you for your response, you are correct it is only when AC has been on ( Florida AC only ) I will try what you have suggested thanks again......
Old Jul 8, 2008 | 04:14 AM
extanker's Avatar
there are some sprays out there for the ac and ya may want to look at the hvac filter
Old Jul 8, 2008 | 05:41 AM
78buckshot's Avatar
Make sure the condensate is draining freely from the A/C evaporator/heater box. Do you have wet carpet or blowing water out of any of the outlets? I'm not up on the C5-C6 but all A/C units have to be able to get rid of the condensate, should be a rubber drain nipple on the bottom of the A/C evaporator/heater core box-just make sure it's clear.
Old Jul 8, 2008 | 05:57 AM
extanker's Avatar
ORIGINAL: 78buckshot
very good .i forgot about that
Old Jul 8, 2008 | 06:20 AM
WHISTLER53's Avatar
Thank you both for the info.... My question is where is the HVAC filter located &when exhaust is changed on Thursday I will check the rubber drain nipple.... thanks again
Old Jul 8, 2008 | 11:10 AM
extanker's Avatar
ORIGINAL: WHISTLER53
on an 07 z06 its right side engine compartment ,firewall, 3 clips
riley6riley
Jun 24, 2008 09:37 AM
c44me
Oct 29, 2005 12:20 AM
humvipcorssr
Sep 16, 2005 03:48 PM
97C5 Owner
Sep 9, 2005 02:05 PM
jws1600
Aug 23, 2005 12:13 PM
