Corvette C6 Forum 2005+
Top Popping/Leaf Spring Adjuster Replacement
Old Dec 1, 2019 | 02:43 PM
dmad1's Avatar
Talking Top Popping/Leaf Spring Adjuster Replacement
Had a rear leaf spring adjuster break off. Opened both doors, hood, deck lid and released all 3 top latches. Jacked up the rear and placed on two jack stands under the center of the leaf spring bolts. Replaced the adjuster. Top noise has disappeared. Coincedence? Top has made noise since new. This was my biggest complaint about the car. Since replacing the adjuster it has been a pleasure to drive. I feel sure the popping will come back but for now, I am sure enjoying the quietness.
Old Dec 2, 2019 | 06:27 PM
Not familiar with the C6 suspension but perhaps it previously was in some sort of bind and replacing the adjuster got everything lined up correctly.
Old Dec 2, 2019 | 07:15 PM
dmad1's Avatar
I think you may be correct. I had always heard that you should pop all the latches and doors when jacking it up so I unlatched all of them. Seems as if it may have just taken all the binding out of things. Our streets are full of holes and cracks and the noises with the top have not returned as yet. I hope it lasts for a while. Thanks for the reply. I think at one time, the Zs didn't have removeable tops. Would like to have one of them. dm
pistolgripump2
Dec 15, 2014 09:12 PM
bruiserman
Sep 29, 2007 09:05 PM
farmetr
Nov 10, 2006 01:17 AM
troussos
May 18, 2006 02:32 AM
gnvenom
Jun 15, 2005 01:50 PM
