1985 corvette not charging
Old Apr 24, 2010 | 02:55 PM
ourcrazylife7's Avatar
Default 1985 corvette not charging
new computer,new battery,new alternator. will start and run with jump but system will not charge while running. low amp about 8.5
Old Apr 26, 2010 | 09:07 AM
chrish4161's Avatar
Everything you described is new and running perfectly as you say but your system is not working and charging is not done then now you have only one option, and that is system checking. if you can then check your system charger related wiring and the sockets. I am sure problem should be there only.
ShanShaw
Apr 14, 2013 11:02 PM
1996sho
May 7, 2007 01:15 AM
bobbiebello
Jun 18, 2006 10:53 AM
GrtAmrTrkr
May 31, 2006 10:03 PM
vettey
Jan 21, 2006 02:25 AM
