C4 oil leak at cat. Converter???
Old Jun 3, 2009 | 07:12 AM
POLOG91's Avatar
Default C4 oil leak at cat. Converter???
About 200 miles ago, I shut down my 1991 (42k miles) & smoke started to waft from under the hood at the driver side. It reeked of burning oil. That was the 1st time the car was out after an oil change. I went right to the shop ... It didn't smoke so bad when I shut it down there. They found the filter was tight & couldn't discover the source. We looked under the car, the oil was dripping from the fins in the Cat. Converter!! They cleaned it up, but the 6 times I've used it since, my garage stinks of oil when I shut it down. It's not smoking now & there is no oil on the floor (there never was), but something must be feeding the stink - if it was a sloppy oil change it should have all burned off by now. Anybody have any ideas?? What could leak & drip through the converter? Thanks.
Old Jun 3, 2009 | 07:18 PM
xfasteddiex's Avatar
my 1990 with 140k does it all the time chevrolets are bad about the intake gasket leaking where the intake meets the block . mine leaks there & runs down & drips on the converter .
Old Jun 3, 2009 | 07:53 PM
partsman41's Avatar
There's also an oil pressure sending unit back there that I have had leak,VERY difficult to find!
Ron
Old Jun 4, 2009 | 05:24 AM
POLOG91's Avatar
Thanks, guys. I'll investigate.
Sullyvette48
Jul 8, 2019 04:47 AM
santaman58
May 13, 2007 10:25 AM
89rdstr
Apr 28, 2007 03:34 PM
LT4Dave
Oct 10, 2006 02:27 PM
mazie
Oct 3, 2005 12:32 AM
