door latch
Old Jun 24, 2007 | 01:04 PM
george chard's Avatar
Default door latch
door stuck can not open, got it open once, changed latch assembly, worked fine untill i put inside door panel back on now it will not open again ???????? brothers car think its a 1979.
Old Jun 24, 2007 | 03:34 PM
Default RE: door latch
ORIGINAL: george chard
Is it possible that something is binding against the linkage, rather than the linkage has disconnected?
Old Jun 24, 2007 | 10:32 PM
I dont think its that easy, I was hopeing someone had the same problem. its been a while but i need to look at it again. thanks.
Old Jun 25, 2007 | 10:45 PM
pg's Avatar
Hi George Chard, and welcome to the forum. There is a tool called a " Slim Jim" . It's a flat piece on metal that slips down between the outer glass and once in there you wiggle it around to get the door to unlock. Cops have them and so does "AAA" and so do the tow truck drivers see if you can get the cops to help you unlock the door and then you can figure out what's wrong in there. PG>
Old Jun 26, 2007 | 08:29 PM
Thanks for the tip..
Old Jul 1, 2007 | 09:38 PM
any other thoughts
Old Jul 1, 2007 | 10:18 PM
pg's Avatar
Hi again, sorry I gave you bad information. I forgot that the latch control rods on our cars is between the door trim and the door skins on the inside of the car. I just looked a page 11-8 in the Haynes Manual to figure out why you still had the problem. Do you have that book or a catalog to get an idea of what it looks like in there.With the window down there might be enough room to open it with a coat hanger. PG.
Old Jul 4, 2007 | 07:13 PM
thanks again
gracing76
Jun 9, 2009 09:25 AM
becuzitsthere
Mar 9, 2006 03:56 PM
Robert
Feb 18, 2006 03:38 PM
Wifes81
Aug 12, 2005 12:28 AM
flower
Jun 23, 2005 02:57 PM
