fuel gauge problems 82 corvette
Old Sep 20, 2008 | 10:30 PM
donald's Avatar
Default fuel gauge problems 82 corvette
fuel is definitely full but gauge is reading 1/4 of a tank. when i unplug the connector wires back at the tank the gauge moves way past full. when plugged backed in it goes back to 1/4. voltage is 3.34 volts and the sending unit( i think ) is reading 21.4 ohms. this is as far as i have gotten. appreciate any help.....
Old Sep 21, 2008 | 10:17 AM
DeeVeeEight's Avatar
Banned
Default RE: fuel gauge problems 82 corvette
Hi Donald. The fuel sending unit is a variable resistor that is actuated by a float, located inside the fuel tank. It sounds like your float is stuck or that the resistor has gone bad. Try shaking the car to slosh the fuel around in the tank to try and free up a possible stuck float, other than that, you may need to remove and replace the sending unit.
Est. 1965 free catalog express order Contact Us Login My Cart All Years 2009 2008 2007 2006 2005 2004 2003 2002 2001 2000 1999 1998 1997 1996 1995 1994 1993 1992 1991 1990 1989 1988 1987 1986 1985 1984 1982 1981 1980 1979 1978 1977 1976 1975 1974 1973 1972 1971 1970 1969 1968 1967 1966 1965 1964 1963 1962 1961 1960 1959 1958 1957 1956 1955 1954 1953 Search for: Printable Order Form | Gift Certificates | Used Parts | Dealers
1978-81 (C3) Gas Tank Sending Unit
Corvette Gas Tank Sending Unit, 1978-1981
[ul][*]Reproduction Of Original [*]Includes Filter (Strainer) [/ul] This Corvette reproduction gas tank sending unit has been manufactured to original factory specifications using today's modern manufacturing techniques. You will find the fit and function will work superbly for your restoration. In addition, using a reproduction gas tank sending unit from Eckler's will add authenticity and value to your Corvette.
Did you know?Many people in our hobby refer to the gas tank sending unit as a gas tank sending gauge.
Item#A8385 In Stock
$159.99 ea.
Qty:
Related & Other Items Of Interest:
Part # Description Price 35624 Corvette Gas Tank Sending Unit Strainer, ACDelco, 1956-1974, 1978-1981 $12.99 EA.
Other Popular Items Corvette Frame To Fuel Pump Fuel Hose, 1970-1981 Item#A8360 $11.99ea. Corvette Gas Tank Sending Unit Gasket, 1978-1982 Item#22966 $4.99ea. Corvette Fuel Vapor Return Hose, 1968-1981 Item#A8361 $9.99ea. Why Eckler's? •Over 40 Years In Business •Money Back Guarantee •Fast Shipping •Guaranteed Lowest Prices •Over 20,000 products •Technical Expertise •A Name You Trust Need Assistance?
Home | Free Catalog | Express Order | Contact Us | Basket
Privacy/Terms Statement | Comments | Guarantee/Returns | Events | AOL Issues Copyright ©2008 Eckler Industries, All rights reserved. Titusville, FL 32780 - 1-800-284-3906
[sm=icon_cheers.gif]
Old Nov 25, 2008 | 08:11 PM
corvettey's Avatar
Did you ever get this fixed? I also have this problem. Thanks.
Old Nov 15, 2009 | 03:46 PM
Gustine's Avatar
Default fuel gauge
It works like a "bobber" system (that's if you go fishing). There is a Fuel Level Sender that basicly looks like a bar with a handle on it located right above the fuel pump and all it does is float. That is where you get your reading, primative but that is where you get a great fuel reading on a down hill slope and a horrible one going up hill. If it is stuck that floater will stay and, that is where you get your constant 1/4 reading, or if it is stuck at a 1/2 you get that one etc... I would check that first before I went nuts on anything else, and no you do not have to drop or drain the tank, it pulls out with the fuel pump and as long as you are extremely careful and sure handed, but if anything gets in the gas tank while you do this, then guess what you've got to do. So be methodical when you do this.
Old Nov 19, 2009 | 10:59 PM
D.Waype's Avatar
im trying to hook a air/fuel gauge up in my car but cant find out which wire going to my o2 sensor i need to splice into?? any help or suggestions would be greatly appreciated
Old Dec 13, 2009 | 04:45 AM
sunsets09's Avatar
The f100 short bed I have needs a new tank and I do not like it behind the seat. So I want to relocate it under the bed and behind the rearend. Does any one Know of a factory tank that will fit or anyone that has relacated theirs in a better location or different type of tank? Any help would be great?
Old Dec 13, 2009 | 09:07 PM
This may be better asked on Fordforums.com.
you could always get a rear tahk from a junkyard.
chrisdann1
Mar 4, 2009 03:10 PM
buddym3
Jul 2, 2007 02:08 PM
KenHorse
May 28, 2007 05:26 PM
DSMKilla
Feb 13, 2007 11:51 AM
chaddeaux1
Sep 23, 2005 05:23 PM
