Hood Problem
Old Aug 6, 2006 | 07:59 PM
Eroc's Avatar
Default Hood Problem
I have a 1978 vette. And have a problem and wanted to see if anyone might have a idea how to fix it. The handle you pull to open the hood has broke. I can pull on the cable and only one side of the hood will pop open the other side is locked down and I cant get it to open.I really really dont want to have to cut the hood to get that latch open. So please help if you have any ideas let me know.
Old Aug 6, 2006 | 08:14 PM
Default RE: Hood Problem
Go to C3 forum. You may find an answer. Good luck!
Old Aug 6, 2006 | 11:39 PM
GrtAmrTrkr's Avatar
I had the same problem this spring, if its the passenger side that is stuck you need to lift the driver side of the hood as much as possible ( i used a tennis ball between the fender and the hood to hold it open ) be careful not to crack the hood. if you look under the proped up side of the hood you will be able to see the latch, on the right side of the latch you will find the crossover cable (this goes to the other latch) pull the cable (I used an aluminum rod and bent a hook on the end) and as long as the cable isnt broken the hood should release. The crossover cable seems to stretch , there are several holes driller on either end of it to allow you to tighten it. I replaced mine. ( Ecklers $24.00 ) hope this was helpful good luck ,let me know how you make out.
GrtAmrTrkr
Old Aug 8, 2006 | 08:16 PM
corvette king's Avatar
I KNOW ECKLERS CORVETTE SELLS A TOOL TO OPEN THE HOOD IF THE LATCH FAILS.GOOD LUCK
Old Aug 12, 2006 | 02:22 AM
GrtAmrTrkr's Avatar
The tool that Ecklers sells is for C4 vetts with the hood release in the fender, it wont work on a C3. However there is a body plug in the wiper tray that can be removed, but I still could not get the latch through it, not enough room to get a long enough screwdriver in ( too close to windshield ). After I got mine open , I drilled a hole directly behind the latch and placed a body plug in it. So if my cable streches again all I need to do is remove the new larger plug and pop the latch.
Good Luck !!!
[IMG]local://upfiles/1422/16B69F37BEAD4A17B814E8B0039AE26B.jpg[/IMG]
Texas Jim
Jan 23, 2008 01:10 PM
reactor2
Sep 4, 2006 09:33 PM
mertztr
Mar 21, 2006 11:18 PM
Robert
Feb 18, 2006 03:38 PM
flower
Jun 23, 2005 02:57 PM
