84-85 vette steering column ?
Old Sep 26, 2012 | 10:33 PM
Smith Brother's Avatar
Question 84-85 vette steering column ?
Hello,
I have a Buick street rod I built in the late 90's. I am using a Vette column from a 84 or 85 total.
I am installing a fiber optic light in the dash to show HIGH BEAM. I need to pick up feed for such, and need to know the location on the column connector for the HIGH BEAM. My wire harness says, LIGHT GREEN, but the light green wire I have found doesn't do the trick.
The fiber optic kit has three lights, and a ground. Two for turn signals, and one for HIGH BEAM.
Am I not heading in the right direction for this app? I could go in the engine compartment and find the high beam wire and hook in and feed back thru the firewall/cowl, but would prefer to pick up from the column.
I'm a new member, and Thank You for your help.
Dale in Indy
Old Sep 28, 2012 | 10:30 AM
I figured it out, I remembered that the DIMMER switch is on the left side of the column, and THERE I found the wire I needed.
I off and running, just having fun, FUN IS GOOD!
Dale in Indy
sorlowski
Dec 3, 2008 07:38 AM
Fuzzy74
Sep 14, 2006 05:43 PM
Fuzzy74
Jul 16, 2006 07:07 AM
Rick854
Jul 2, 2006 06:41 AM
Gorilla
Sep 16, 2005 02:36 PM
