C3 Headlights won't raise but will lower
Old Feb 17, 2016 | 01:36 PM
DwSimpson's Avatar
Default C3 Headlights won't raise but will lower
I've came across an issue with the headlights on my 1978 L82. My headlights will not raise when I pull the headlight switch but if I disconnect the small white hose going to either relay valve both headlights raise right up every time. Then once I reconnect the hose both lights immediately lower. Either valve being disconnected will raise the lights, and it doesn't matter what position the headlight switch is in, on or off, just as long as the car is running. If I manually raise the headlights while the car is off and then turn on the car while the headlight switch is in the off position both lights go down. I've recently installed a new seal on one of the actuators, the other holds pressure fine. And the relay valves are brand new and my headlight switch is new. Any thoughts of what might be my issue??? I need help!!!
ktrixx
Sep 11, 2010 12:48 AM
teamodeee
Oct 1, 2008 07:51 PM
Red Pierre
May 28, 2007 10:48 AM
palmbayvette
Mar 23, 2007 09:35 AM
Barry
Mar 12, 2006 03:05 AM
