79 corvette
Old Aug 25, 2022 | 11:01 AM
Driver's Avatar
Default 79 corvette
Hello everyone iam new here I have a 79 corvette I know.but I love her. Has a 350 run great all year yesterday it just quit going down road.started back up drove home on stop and go basis but got there.replaced fuel lines fuel pump ignition relay has new accel distributer new plugs plugwires elder rock carb.so stil starts then stalls.turn key starts up runs a minute shuts off instantly no sputter just off.let it sit starts but up stops.I’m so agervated I don’t know what to do at this point.I’m not a mechanic but have worked on lots of motors can’t figure this out can any one help.
Old Aug 25, 2022 | 06:32 PM
Welcome to the forums! Always a bummer when you have trouble with your baby! My brother had a 79, a very nice car.. Ok--No sputter, does not sound like a fuel issue. Sounds electrical. When was the distributor installed? After it started stalling or was it installed before it started stalling? I think I would check the wiring + and-connections outside of the distributor to see if they're tight. And the wire connections on the ing. module. You might want to consider changing the ignition module. The pole Piece has been known to shut things down also. But normally they work or don`t work. (but maybe) Just giving you things to check.. I would be curious to know if there was constant power to the + side of the distributor. If you could hook a test light to the + side of the dist. and start it and see if the light stays on or not even when it dies.That would help eliminate that question. Hope this helps some. Sounds like a little gremlin somewhere!!
Old Aug 26, 2022 | 04:46 PM
Driver's Avatar
Hello again just wanted to say thanks I just put distributor 3 months ago but I went ahead and changed the ignition coil inside now it runs great 👍 just goes to show not all new parts last but thanks everyone
Old Aug 26, 2022 | 05:37 PM
Ya new parts these days it`s hit and miss sometimes. Good glad you found it! Back on the road!!
Justintcrow
Jun 10, 2021 02:07 PM
jammer123
Apr 8, 2009 03:51 AM
scotth48
Sep 23, 2008 06:25 PM
rwlvette
Nov 11, 2005 09:15 AM
