body mounts
Old May 9, 2007 | 09:33 PM
Fuzzy74's Avatar
Default body mounts
I am taking the body mount bolts out and everyone I took out took the mount with it, thats how bad it is rotted. a couple i snapped the bolt. how am I going to get the body off of the frame now? can anyone help?
Old May 9, 2007 | 10:45 PM
Rich G.'s Avatar
Default RE: body mounts
If the bolts snapped there will be nothing holding the body on so it should just come off. I couldn't get my two rear bolts off so I got a wiz wheel and just cut the heads off and drove the bolts up.
Old May 9, 2007 | 11:35 PM
Fuzzy74's Avatar
awesome, so it shouldnt hang up on the fiberglass? if it does do you suggest to cut the fiberglass around the bolt and patch it up later? and after the body mounts are out what else would I have to do to lift the body? I have the noland adams video comming but i guess im in suspense. This is my first ever project if you cant tell haha! thanks all!
Old May 10, 2007 | 07:53 AM
If at all possible, DON'T cut the fiberglass.
Old May 10, 2007 | 08:08 PM
78buckshot's Avatar
I was able to get all mine out by heating the 'nut' first and then gently use the impact wrench back and forth, you should not have to cut any fiberglass to get to the bolts or mounts.
Old May 10, 2007 | 09:07 PM
Nut crakers work well in some places. Lots of penetrating oil, left over night, and yes, heat will expand the nut and help break it loose.
Old May 10, 2007 | 09:18 PM
ORIGINAL: C3 Starship
Kroil works real good.
Old May 10, 2007 | 10:03 PM
Heat...Just remember fiberglass is VERY flammable.
Old May 11, 2007 | 11:14 PM
Actually it's just the resin that burns but I know what you mean. And even if it doesn't catch on fire, it'll sure melt. I saw a burned out hulk and just seeing a bunch of glass strands all over looked strange. Sad too.
ikitte
Apr 9, 2007 02:11 PM
arfdog123
Oct 2, 2006 05:00 AM
Dvette
Apr 15, 2006 04:06 PM
9C1 WS6
Oct 10, 2005 11:46 AM
mxw128
May 30, 2005 12:55 PM
