Brake Lights
Old 06-10-2012, 12:37 PM
SCHOON's Avatar
Default Brake Lights
When the car is off and I step on the brake pedal the brake lights come on and go off when I take my foot off the pedal.
When the car is running and I step on the pedal the brake lights come on but don't go off when I take my foot oof the pedal.
This is when I need to lift the pedal up with the top of my foot to turn off the lights.
About 1/16" of play at top of pedal.
I tried adjusting the switch but it didn't help.
Old 06-11-2012, 12:16 AM
I'd try taking the switch out of the bracket and seeing how it reacts when doing it manually.
Old 06-11-2012, 08:04 PM
SCHOON's Avatar
I removed the switch and it is working fine.
This time I adjusted it with the car running and now the lights are working almost ok.
Seems like the pedal is hanging up a little on then return causing the lights to saty on.
Is there a place under the dash to lube the pedal?
Schoon
Old 06-11-2012, 11:12 PM
Maybe try squirting some lube at the pivot point. While WD40 will work for a while, an oil based lube will last longer. Also where the rod attaches to the arm.
gigabyte
11-15-2008 07:12 PM
iwantfast
09-24-2008 10:41 PM
shevey
09-23-2008 10:19 PM
IVAN1215
Technical Diagram Help
09-24-2007 01:50 PM
vettemanrob
09-22-2006 09:59 PM
Quick Reply: Brake Lights
