hard clutch
Old Jul 3, 2018 | 06:37 PM
rogerlon's Avatar
Default hard clutch
my clutch is real hard to push in, is the stock one this hard.what would be a easier onto Put in.
Old Jul 4, 2018 | 11:42 AM
My clutch was always easy to push in which is why I plan on replacing it with the OEM Borg Warner clutch. Sounds like you may have a high-performance replacement.
Old Jul 4, 2018 | 12:39 PM
rogerlon's Avatar
thanks for the reply, i guess I will have to go with a stock clutch. when I was younger I wanted that type of clutch. lol
Old Jul 23, 2018 | 06:24 PM
rogerlon's Avatar
Default new clutch
put a new 11 inch clutch in my 75 corvette, but could not get the one inch pedal play . some where along the line someone may have changed some thing. solved the problem with a 65 corvette adjustable lower arm. now works great.
Old Jul 23, 2018 | 09:45 PM
Didn't your clutch push rod have a double nut adjustment on the crank arm next to the left side of the engine?
Old Jul 24, 2018 | 09:51 AM
rogerlon's Avatar
yes , but it would run out of tread like it was to short
Old Jul 24, 2018 | 01:42 PM
Did you replace anything besides the clutch?
Old Jul 24, 2018 | 03:55 PM
rogerlon's Avatar
no, but I did notice a lot of side movement on the clutch pedal. may need new bushings , but I do not have a idea how to get in there other then pulling the dash out.
lcvette99
Oct 23, 2017 09:25 AM
93c4matt
Sep 19, 2008 12:34 PM
whytry
Jun 5, 2007 08:04 PM
Herb
Nov 17, 2006 08:01 PM
Ren
Oct 21, 2005 06:24 PM
