Visor bushings on 1982
Old Jul 15, 2024 | 07:51 AM
Cajunmg's Avatar
Default Visor bushings on 1982
How do you install the visor rod with the new white plastic bushings on the elbow.I have tyed to push the rod into the elbow with new bushing will not go in all the wy
Old Jul 15, 2024 | 08:58 AM
Welcome to the forums. Without looking at it I can't say what the issue is, you can compair the new bushings with the old and see if there is a difference between them. Zip Corvette parts has some instructions on how the visors are assembled, and YouTube has some assembly information on visors also.
Old Jul 16, 2024 | 11:59 AM
Welcome to the forum. As Thomas said, Zip and also several Corvette aftermarket suppliers publish DIY instructions. If all else fails, you might try to get an Assembly Manual from one of them to see if it helps.
Old Jul 16, 2024 | 07:28 PM
Maybe try inserting the plastic bushings first then install the rod into it.
Old Jul 17, 2024 | 10:42 AM
Cajunmg's Avatar
I have tried to push the rod into the bushing in the elbow will not go all the way in.Tryed putting the bushing on the rod ,then trying to push it into the elbow will not go..
Old Jul 17, 2024 | 12:35 PM
74HARLEY's Avatar
It's possible that the bushings are not made correctly. Do you have an original to compare with?
Old Jul 17, 2024 | 07:16 PM
Bigger Hammer. Yes compare something is not right. They should snap together. You might need to modify it.
Old Aug 12, 2024 | 11:57 AM
Did you get the issue resolved with the plastic bushings, I'm curious.
Bert Higgins
Jan 27, 2020 11:14 AM
Sweetness224
Jan 9, 2009 04:42 AM
LT4Dave
Oct 12, 2008 07:25 AM
bruiserman
Sep 7, 2008 07:11 AM
halsted
Jan 4, 2008 05:42 PM
