Weak air flow from 69 blower
Old Feb 18, 2008 | 08:25 PM
Longtimeowner's Avatar
Default Weak air flow from 69 blower
My original heater/ac blower is weak in my 69 convertible.It still has all settings working, but not much air flow. Could I replace it with a newer model blower that forces more air? If so, which model?
[IMG]local://upfiles/4763/04478B5842BE4C289CECC6E88D9D9BF2.jpg[/IMG]
Old Feb 18, 2008 | 08:39 PM
Default RE: Weak air flow from 69 blower
Welcome to the Corvette Forum. Are you sure that the ductwork is clear and doesn't have any wildlife homes (nests) in it? If so, a new blower motor should do the trick. A point of interest on the GM blower motors (at least the ones in our generation Corvettes) is that they use a bronze bearing that is lubricated by a oil-soaked felt washer on each end.When the felt runs dry, the bearing soon goes dry and the fan will usually run slower and/or noisier. [] After I discovered this, I successfully re-oiled the felt washer by drilling a hole in the housing next to the washer and adding oil using a small syringe. Got to keep that numbers matching blower motor, dontcha know. Actually I did this while I was in the Navy and disposable income was on the low side. Today would probably just go buy a new one.
Old Feb 18, 2008 | 09:27 PM
Thanks for the reply. I have owned my 69 since 1974. I replaced the blower many years ago when it was making a lot of noise so numbers may not be the same. As you know these c3's get very hot inside during the summer. I have already put down a new layer on insulation on the floors, which has helped, but now that I am older the heat gets to me more. I cleaned the duct work and sealed it last summer, but the flow is still weak. Would using an 80's blower work?
Old Feb 19, 2008 | 03:40 PM
If it will fit, I wouldn't see why not. I sort of remember a discussion of this in a magazine or forum several years ago. Might take some measurements of a C4 motor to see if it'll fit.
Old Feb 21, 2008 | 08:22 PM
Flying Low's Avatar
Hey Longtimeowner, did your duct cleaning include cleaning the heater or a/c core they can act like a dirty air filter. Maybe some of the pro's can tell you if the air is routed thru there all the time or just when directed to.
Old Feb 21, 2008 | 09:48 PM
Good call Flying Low. The air always goes thru the evaporator but only goes thru the heater core when calling for heat.
Old Feb 22, 2008 | 05:31 PM
Thanks all for the advice. I have since talked to a fellow shark owner nearby that has replaced his blower motor with a C4 type. He had to make a 3/4 inch gasket because the assembly is larger. He tells me it makes a big difference. Once the snow is gone and I can make more room to work on it, I am going to replace the old motor for a C4. Thanks again.
Old Feb 22, 2008 | 09:26 PM
Please take some pics as would like to see how it fits. Might give it a whirl.
repodude43
Mar 9, 2007 07:56 PM
crankyyank
Oct 2, 2006 08:55 PM
liviz40102
Aug 14, 2006 04:20 AM
kvette
Oct 24, 2005 01:16 PM
PAULKR
Sep 11, 2005 05:49 PM
