1992 unknow problem
Old Jan 12, 2008 | 08:22 PM
  #11
Default RE: 1992 unknow problem
Check your engine vacuum at idle, then raise the rpm to 2000 rpm and hold it. If the vacuum doesn't return to what it was at idle, then you have a restricted exhaust. (Catalytic converters)
Old Jan 13, 2008 | 12:42 PM
  #12
frank j's Avatar
I have read your post ric i have a 92 and have experienced the same problem. you have4 areas that can cause the problem you described.
1 fuel
2 exhaust
3 electrical
4 your distributor
the distributor is a nortorius unit wich is very tempermantal in my opinion i would think and bet it is the non vented distributo that has you all messed up
Old Jan 14, 2008 | 09:05 AM
  #13
LeesVette's Avatar
ORIGINAL: frank j
1 fuel
2 exhaust
3 electrical
4 your distributor
If it was the optispark it would (at least it should)be throwing a code(s). Code 16 and/or 36 to be exact.
sbmania
Jul 7, 2014 09:37 AM
okvette92
Aug 16, 2006 05:03 PM
RobertAz2005
May 25, 2006 04:08 PM
markone
Apr 21, 2006 05:47 PM
JRGonzo
Nov 14, 2005 01:11 AM
