power steering problem
Old May 26, 2007 | 12:17 PM
scooterman's Avatar
Default power steering problem
I've been having an issue with my power steering not working on start-up, so after reading about a few similar issues on the forum i decided to replace the pump. No luck- if anything it's getting worse, Am I looking at replacing the rack? Suggestions?
Richard
Old May 27, 2007 | 11:36 PM
Default RE: power steering problem
What is happening is the internal seals on the rack are hard and bypassing pressure when cold. After the fluid heats up and in turn heats the orings and softens and enlarges them, thet swell and seal and you have p/s. In other words, YES, you are looking at replacing the steering rack. Good Luck![8D]
Old May 28, 2007 | 06:05 AM
mypetu39's Avatar
Mech259, I have in my files a Technical Bulletin from General Motors which addresses this issue. I'll give you the website below for your reading pleasure. I have replaced the power steering fluid with the fluid mentioned in this Technical Bulletin and experienced very little difference. I'm up here in Ontario, Canada, where the temperatures during the first, and last, of our Corvette "Summers", are somewhat cooler than down South. Let me know when you have read this Bulletin if it seems "right". Thanks.
http://service.gm.com/servlets/BlobS...=-1&evc=sm
mypetu39
Old May 28, 2007 | 06:58 AM
I tried the link and get the old "HTTP 404" dead link.
Old May 28, 2007 | 09:40 AM
scooterman's Avatar
I was afraid you were gonna tell me that. have you had any luck flushing power steering? I run a shop and we use wynns products- I'm gonna give it a try first. I can get a reman pretty cheap but it looks like it's a bear to get to- Thanks for the reply!!
Richard
Old May 28, 2007 | 03:34 PM
If you have a rack available, it is not that bad. Good luck on flushing, rather you try a conditioner, although you are probably wasting your time.
gracing76
Feb 24, 2008 08:51 PM
Rickcusaf
Nov 21, 2007 01:03 PM
lil red corvette
Jul 10, 2006 09:59 PM
imb1987
Feb 8, 2006 12:38 PM
gs821
Jan 12, 2006 12:27 PM
