Shifting problems
Old Aug 2, 2006 | 03:58 AM
Chevy4Fun85's Avatar
Default Shifting problems
I bought an 85 vette and it has a 4+3,if u go to far to the left 1st & 2nd will not go in, unless u go to the center of the shift box and go slightly to the the left. It fells like the shifter is sloppy, also if u downshift from 3rd to 2nd it does the same thing.Also the instrument cluster doesn't work very well during the day and u can't see the cluster at night.Any and all advice is helpful.
Old Aug 2, 2006 | 04:23 PM
TopSpeed's Avatar
Default RE: Shifting problems
Sounds to me like your shifter linkage needs adjusting, or some parts are worn and need replacing. I'll leave the detailed response to the experts here, though...
As for the instrument cluster, there are several places out there to get reconditioned ones....
Old Aug 3, 2006 | 02:51 AM
Thanx top speed, I took it to covette specailist in corona,ca because a smog shop jammed it in 2nd gear tring to smog it.They said it was ok, but all they did was unjammed it from second gear so it would be drivable again.
Old Aug 3, 2006 | 01:43 PM
TopSpeed's Avatar
ORIGINAL: Chevy4Fun85
What a relief!! Good to hear. Please let us know if you are satisfied with the outcome?
DLC360
Dec 26, 2014 05:57 PM
mamcpw2
May 21, 2007 06:26 AM
stevesrubyred93
Feb 28, 2007 10:04 PM
gmracing
Nov 2, 2005 12:01 PM
Bubbie
Aug 5, 2005 08:34 PM
