sticky brake pedal problem solved
Old Aug 14, 2019 | 08:19 PM
espy1949's Avatar
Default sticky brake pedal problem solved
today i was pondering why the brake pedal wouln't return to its normal position.
i dropped the hush panel and using a mirror to guide me i sprayed penetrating oil on the vacuum booster to pedal linkage and pedal pivot point, operated the pedal in rapid succession, sprayed more penetrating oil, took it ourt for a stop n go cruise and all seems to function as it should. no more sticky pedal.
hopefully i got it. at 70 im not sure how many times i wanna go thru that aggravation.
Old Aug 15, 2019 | 09:42 AM
Glad you were able to find the problem and get it fixed. For future reference, you don't need to start a new thread for each post. You can just add to the original thread.
espy1949
Aug 14, 2019 09:55 AM
espy1949
Aug 13, 2019 04:43 PM
dr_maddox
May 12, 2009 11:22 PM
dr_maddox
May 9, 2009 12:12 PM
mikenann
Nov 16, 2006 08:10 PM
