oil pressure
Old Jan 9, 2008 | 04:32 PM
CHEVPAR's Avatar
Default oil pressure
Drove my 2000 vette this morning and the pressure read fine...Went away this evening and my gauge was buried at 80lbs..Oil pressure sending unit bad? Anyone have this problem before? Any help would be appreciated.. Thanks, Brett
Old Jan 9, 2008 | 06:36 PM
Architect's Avatar
Default RE: oil pressure
I have not had this problem (yet), but havereadsimilar threads on this topic, and yes, it seems like its usually the sending unit.
Old Jan 10, 2008 | 08:25 AM
lbelew's Avatar
This happens alot with the C-5's. Do a google search on replacing it. Repair manual calls for pulling the intake, but some have found it easier to punch a hole in the plastic directly overhead. I picked up my replacement sensor on ebay for $25. Good luck.
Old Jan 13, 2008 | 05:33 AM
extanker's Avatar
first turn key ,dont start motor. if psi is buried its the sending unit.you dont have to remove the intake,just unbolt stuff so you can lift slightly and move foward to gain access.you can reuse intake gaskets,use a TQ wrench,and wash the top of motor before taking apart.first time it will take a tad over an hour,then each time shorter cuz its gonna go bad again.dont go OEM.its called EOP sending unit,3 wire,a sending unit socket will help and dont overtighten
billennium
Sep 11, 2006 03:47 PM
fj40dana@hotmail.com
Jul 4, 2006 01:23 PM
byedan1
Jun 1, 2006 12:30 AM
Patterti
Feb 22, 2006 02:29 AM
Vet Head
Oct 31, 2005 02:17 PM
