Passenger side headlight
Old Nov 17, 2025 | 06:32 PM
Sheriff42's Avatar
Default Passenger side headlight
Hi all! Loving the C5, but I have a really weird situation that has remained consistent for several months.
When I bought the car, the right headlamp wouldn’t rise up. Simple right? I putzed with the adjustment **** and got it to work fine. Only problem is, it only works in the daytime! Everytime it is dark out and I engage the lights switch, it won’t come up! It happened again last night. This morning I went outside and tested it. Went right up!
Is this just a personal gremlin or has anyone else experienced this? I’ve turned off the twilight function, but is there something else DIC related? I can’t see that it would make any difference changing out the motor, but maybe I’m wrong?
I know this sounds crazy, but it’s driving me nuts. Any suggestions appreciated.
Old Nov 17, 2025 | 07:59 PM
I would check and clean he wiring connections. Maybe temperature related, that could be wiring also. You could replace the motor to see if that makes a difference and have a spare. These kind of problems can drive you crazy.
Old Nov 18, 2025 | 12:07 PM
Sheriff42's Avatar
Thanks Thomas! I’ll check connections.
Old Nov 19, 2025 | 11:35 AM
You could try checking the voltage at the motor when the headlight won't come up also.
Old Nov 19, 2025 | 05:22 PM
Sheriff42's Avatar
Got it! Thanks!
Az50thAnniv
Jul 9, 2018 12:53 AM
DLC360
Nov 12, 2014 07:12 PM
palmbayvette
Mar 23, 2007 09:35 AM
capcollett
Oct 16, 2006 11:17 AM
grabie
Feb 17, 2006 06:35 PM
