Shift ball removal
Old Mar 15, 2007 | 12:30 AM
radiowaves88's Avatar
Default Shift ball removal
Hello. Can anyone tell me how to remove the shifter ball on a 2002 with a 6 speed? Is it threaded on or held on some other way? I'd like to install a Hurst C5 shifter ball, but can't get the old **** off. Thanks for your help, Al.
Old Mar 15, 2007 | 01:47 PM
PAY2PLAY's Avatar
Default RE: Shift ball removal
It's threaded, you just have to twist real hard. I actually had to use one of those strap wrenches (not sure what they are really called) to get mine off.
Old Mar 16, 2007 | 07:40 PM
gjswt19's Avatar
if it is a stock **** remove the plastic cap that illustrates the shift pattern and there is a metal piece inside the needs to be pulled out. I tried the strap wrench and torn the rubber inside the shift lever i dont recommend that. here is a link on how to do it.
http://www.conceptualpolymer.com/corvette_install.htm
Old Mar 16, 2007 | 11:28 PM
PAY2PLAY's Avatar
ORIGINAL: gjswt19
I guess I should have mentioned that there was already an aftermarket shift **** on my car when I purchased it, and that was what I used to get that one off. I just assumed it was the same procedure for the stock ****.
Old Mar 17, 2007 | 09:37 AM
gjswt19's Avatar
i learned the hard way
Old Mar 18, 2007 | 12:34 AM
Dave01's Avatar
This method works every time:
Dave
sc6654
Jan 14, 2008 11:22 AM
eewiz
Dec 22, 2006 04:32 PM
spooldup
Sep 25, 2006 12:14 PM
moenl
Feb 23, 2006 10:41 PM
bmbndb
May 12, 2005 10:47 PM
