Corvette C6 Forum 2005+
'13 with Brake Pedal Squeak
Old Jul 21, 2016 | 10:25 AM
dmad1's Avatar
Angry '13 with Brake Pedal Squeak
Had this squeak a year of so ago. Sounds like when the pedal is mashed, the rubber boot is dry. In the olden days, a rod ran through a boot and needed a little lube to get it to go away. The dealer says it can not be lubricated and he replaced the whole brake assembly. It is now doing it again. Anyone had this problem and come up with a fix? Thanks
Old Sep 2, 2016 | 09:54 AM
Check any metal to metal joints and see if lightly lubing them helps. Maybe a little silicone on any rubber parts might help.
Old Dec 13, 2016 | 08:44 AM
dmad1's Avatar
No luck with the silicone. Still getting that rubber squeak/rubbing noise.
Old Jun 22, 2019 | 12:17 PM
Excitable Boy's Avatar
I'm bringing this back up as I recently got a 2013 Coupe and am having the same issue. I thought maybe in teh time since the original post, maybe someone has come up with a fix?
Old Jun 22, 2019 | 02:34 PM
dmad1's Avatar
I originally posted this in '16. Mine is still squeaking!
espy1949
Aug 15, 2019 09:42 AM
espy1949
Aug 13, 2019 04:43 PM
dmad1
May 22, 2016 05:48 PM
dr_maddox
May 12, 2009 11:22 PM
eggbutt
Mar 6, 2007 12:52 AM
