No start from key switch
Old Feb 6, 2023 | 08:59 PM
Russh's Avatar
Default No start from key switch
64 327 power glide will not crank checked all power new starter Checked ballast block checked key switch. Can’t find where neutral safety wire goes to transmission
Old Feb 7, 2023 | 08:33 AM
Welcome from Idaho to the forums. I did see a picture of a switch on another forum. Might help?
Old Feb 7, 2023 | 04:44 PM
Russh's Avatar
Default 64 corvette power glide. How to work around neutral safety switch that does not exist
How do I work around no neutral safety switch so e Gail start
[/QUOTE]
Old Feb 7, 2023 | 11:05 PM
Old Feb 8, 2023 | 09:40 PM
You can disconnect the connector by the transmission and install a jumper wire at the connector. That should get it started if the switch is the problem. Be careful because it will start in a selected transmission gear. I would replace that switch soon if it's bad.
Alans 94 vette
Jun 23, 2007 08:51 PM
TJL74Vette
Jun 20, 2007 09:12 PM
73novice
Jan 8, 2007 04:25 PM
weteyett
Dec 26, 2006 09:29 AM
MVS
Aug 19, 2005 05:21 PM
