Rear end Popping while in Reverse
Old May 24, 2007 | 08:29 PM
69Sharkcoup's Avatar
Default Rear end Popping while in Reverse
Ok while in reverse the rear end sounds like its coming out of the car sometimes. I think it might be a tooth missing on the rear. It does not make this noise in drive. Any ideas.
Rick
Old May 24, 2007 | 08:54 PM
Default RE: Rear end Popping while in Reverse
Try putting two bottles of GM's Positraction additive in the rear end. It might be the clutches sticking. If it does it when you are backing up in a straight line then probably something else.
Old May 24, 2007 | 09:43 PM
If a tooth was missing, you'd hear it goin' forward too.
Do ya have a stick? Sometimes sound travels and it's kinda hard to tell where it's commin' from. Maybe your reverse idler gears are going, if it's a stick.
Although you did say when it's in drive it doesn't make the sound. So I guess ya have an automajic. In that case, try the additive. Check for a loose pinion gear too.
Old May 25, 2007 | 03:48 PM
78buckshot's Avatar
Mine made some real ugly noises before I gutted the rear suspension, found one bad U-joint on the driver's side half-shaft. Put it all back together with new bushings and a composit spring and it's smooth and quiet. Oh 'ya, all new U-joints too.
Old May 25, 2007 | 07:39 PM
Since ya brought up suspension, the center support bushing can make a thump when yamove inreverse or forward. Forward is a more loud thump.
Old Jun 1, 2007 | 09:24 AM
Thanks for the info. While I am changing the exhaust I will check the rear and support items.
aeronos
Jan 4, 2007 09:49 PM
red90vettesc
Dec 6, 2006 09:47 AM
DeepCrush
Nov 13, 2006 01:04 AM
markcuc
Oct 6, 2006 04:45 PM
daskrizzo
Apr 4, 2006 03:43 AM
