1995 Corvette Brake Pedal Sticks (6sp base)
Old Jul 16, 2023 | 02:18 AM
Silverspoon's Avatar
Default 1995 Corvette Brake Pedal Sticks (6sp base)
My brake pedal doesnt come up that last like 1/4in to the top to disengage the brake lights without me putting my foot under it to help it. Last fall I had a new master cylinder and new fluid put in, but the problem still persists. Is there a place to buy the brake pedal assembly since there is no return spring to this setup?
Old Jul 16, 2023 | 01:58 PM
Not sure what's supposed to return the brake pedal if there is no spring. All I could find online is that the master cylinder acts as the pedal return. So if you put in a new master cylinder and it's not returning, then you might check the master cylinder.
Old Jul 16, 2023 | 05:26 PM
The new master cylinder left me in the exact same position as the stock one...
Old Jul 16, 2023 | 06:59 PM
If it acts the same way there could be a problem with the brake booster or the brake pivot shaft hanging up. I believe they pivot on nylon bushings, not likely to bind. To check the booster and master cylinder for travel unbolt the booster from the firewall (and back the booster off maybe an inch or two) and see if that changes the travel issue.
Old Jul 17, 2023 | 12:49 AM
We will try that. Thank you!
C3 Jim
Aug 2, 2022 09:49 PM
Silverspoon
May 24, 2022 08:02 PM
RatFink60racing
Jun 13, 2021 09:02 PM
espy1949
Aug 13, 2019 04:43 PM
dr_maddox
May 12, 2009 11:22 PM
