'89 Starts Cold Runs Fine Won't Start When Turned Off
Old Jan 24, 2008 | 11:24 AM
riohippy's Avatar
Default '89 Starts Cold Runs Fine Won't Start When Turned Off
1989 - Starts great, runs right until I turn it off. When I try to start it again it doesn't want to start until cooled down. Have had it checked by two machanics -- neither could locate a specific problem. One recommended a new coil and/or fuel pump. The other recommended new spark plug wires. What's up? Thanks for any suggestions.
Sorry - originally posted as a '84 (another of our cars)
Old Jan 24, 2008 | 01:38 PM
extanker's Avatar
Default RE: '89 Starts Cold Runs Fine Won't Start When Turned Off
lets assume its cranking over fine. when it doesnt start check for spark,if ya got spark check for fuel.you can check for spark by pulling off a plug wire and putting a screw driver in the boot ,hold it 3/8 of an inch to ground then have someone crank it over.you want a nice crisp spark jumping off the screw driver to ground.fuel testing need test equiptment
Old Jan 24, 2008 | 01:40 PM
extanker's Avatar
by the way if those wrenchs checked this car while it didnt start one is an idiot,dont go back to that one
Old Jan 24, 2008 | 02:18 PM
LeesVette's Avatar
Fuel injectors. Starts fine cold then hard to start when its hot or won't start at all after the initial start?
Old Jan 24, 2008 | 03:08 PM
extanker's Avatar
ORIGINAL: LeesVette
8 of them went bad at the same time?
Old Jan 24, 2008 | 05:07 PM
3BlkC4Ragtop's Avatar
ORIGINAL: extanker
ORIGINAL: LeesVette
Mines a 1989 too.. it sat for a while beforeI got it.. it ran good for a bit after Igot it.. then the injs needed rebuilding..
acted EXACTLYlike you describe..
yes itcould belots of things.. but my INJS fixed mine.
Old Jan 24, 2008 | 05:23 PM
extanker's Avatar
ORIGINAL: 3BlkC4Ragtop
ORIGINAL: extanker
ORIGINAL: LeesVette
you rebuilt the injectors?they sell rebuilding kits for them?
Old Jan 25, 2008 | 08:36 AM
LeesVette's Avatar
I don't know if they sell the injector kits but I know the ones for LT-1's can be R&R'd.
Old Jan 25, 2008 | 09:22 AM
extanker's Avatar
ORIGINAL: LeesVette
remove and replace ? hey riohippy whats up with yer ride? fix it yet
hereitis1967
Jul 23, 2012 07:33 PM
OzoneTrash
Jul 5, 2008 02:28 AM
rjensen
Sep 5, 2007 10:22 AM
mcu643
Jan 6, 2007 11:48 PM
